Login issue in ZAPTEST FREE EDITION
Home Forums Ask Expert Login issue in ZAPTEST FREE EDITION
Viewing 12 posts - 1 through 12 (of 12 total)
  • #31015
    abhinav kumar
      When we are try to login to ZAPTEST Free Edition while using our credentials, we are getting message as ‘Proxy Credentials Are Required’. Snapshot is attached.
      Not sure what to enter here. Kindly help.
      Regards Abhinav
        Hi Abhinavmalviya1992!
        It means, that you have configured a proxy on your computer. You should use your proxy credentials and also could save them in ZAPTEST configuration.
        ZAPTEST uses system settings and you could change/set it using the “Internet Options” dialog:
        1. Open Internet Explorer
        2. Find and click “Internet Options” menu item
        3. Open “Connections” tab
        4. Click “LAN Settings” button where you will be able to update your proxy configuration
        abhinav kumar
          Done.
          But now not able to launch the application.
          The tool is running as process in background but not visible,
          #31018
            Have you seen the login dialog before? If yes – could you try remove this configuration file: “C:Users{YOUR_NAME}DocumentsZAPTESTPreferencesMainSettings.xml”
            Does it help?
            #31019
            abhinav kumar
              Thanks a ton!!! It worked
              #74684
              lorna lornaroa36
                Experiencing login issues in ZAPTEST Free Edition. Hoping for a swift resolution to ensure uninterrupted testing. Your prompt attention to this matter is greatly appreciated for a seamless user experience.
                #74685
                  Hello lorna lornaroa36,
                  First you need to register to ZAP in our portral, using this URL:
                  Registration
                  Then you can use your same regisatration credentials to login to ZAPTEST Free Edition.
                  Ava Gomes Ava123
                    It seems that the ZAPTEST Free Edition is encountering issues with proxy credentials during login. To resolve this, you may need to enter the correct proxy credentials associated with your network. Consult your IT department or network administrator for the appropriate proxy information and ensure that it is correctly entered in the ZAPTEST Free Edition login settings.
                    #75931
                    Mercy Mercy
                      “I’m deeply grateful for the kindness and support of those around me. Your generosity brightens my days and reminds me of the beauty in this world. Thank you for being a beacon of light in my life[SIZE=1][URL=”https://youtubvanced.org/”%5D%5BCOLOR=”#000000″%5Dyoutube vanced[/COLOR][/url][/SIZE]
                      #77790
                      Shahid shahid
                        Hi, I just installed zap test and get the below error when trying to signup for the free version
                        #78246
                          Hello Shahid shahid,
                          I’m sorry for the late response, we were trying to reproduce your issue but could not get it:
                          Please try again to sign-up, it may be a temporary outage of server.
                          Maeve Maeve785
                            The login issue in ZAPTEST FREE EDITION impedes user access, hindering exploration of its features. Prompt resolution is vital to ensure users can leverage the software’s capabilities effectively. Efficient troubleshooting and responsive support are crucial in addressing login challenges, enhancing user satisfaction and maximizing the platform’s utility.
