Issue with Results
Issue with Results
Home Forums Ask Expert Issue with Results
  • #32100
      Hello tejal1633. Thanks for using ZAPTEST.
      Please make sure you have no “by defaul” option to open html files via Notepad++.
      Please check browser settings in the ZAPTEST – navigate to Tools – Options – General and in “Default Browser” select browser you wish to use for report opening.
      To check your result reports go to Tools – Options – Result Reporting in the ZAPTEST. Here you can find line “Results Folder” and you can go there by clicking “Open” button. Here you should see .zre files of the reports.
      Tejal Karpe
        Thanks, it worked. 🙂
