iOS Veency Agent Installation
- This topic has 1 reply, 2 voices, and was last updated 11 years, 5 months ago by
1. First you need to install the Cydia app.
2. Next, launch Cydia application:
Let Cydia load and update itself (If Who Are You message appears, tap the "User (Graphical Only)" button;
If Essential Upgrades message appears, select "Upgrade Essential" and wait until upgrade is complete).
3. Once loaded, Cydia welcome screen will appear. Tap the Search button and type "Veency" in the search box.
4. Select "Veency" from the results. Tap the Install button and then Confirm button.
5. Once Veency is successfully installed tap on "Reboot" device button (If iOS firmware version is 4.3.5, 5.0 or 5.0.1, make sure to reboot using iOS tool and "Just boot tethered" option as instructed in iOS Configuration video).
6. Once rebooted, launch the Settings app then tap Veency. Set "Show Cursor" option to OFF and enter Password to protect from unauthorized access.
At this point your iOS device is configured for use with ZAP-fiX.
