Impersonation error when running any test
Home Forums Ask Expert Impersonation error when running any test
  • #31961
    Anup Vijayaraghavan
      Hi
      We are trying to see how Zaptest works and when we try to run a basic test, we get this error.
      Error: Either a required impersonation level was not provided, or the provided impersonation level is invalid. (Exception from HRESULT: 0x80070542)
      Can you please advice?
      Regards
      #31962
        Hello anup.vijayaraghavan,
        Please restart the machine where ZAPTEST is being installed and it supposes to fix the issue.
        Anup Vijayaraghavan
          Hi
          I had already restarted the pc. Did it again and same issue.
          Regards
          Anup
          #31964
            Please try the following:
            1. Make sure your system is compatible to the ZAPTEST requirements, which are:
            • OS: Windows 7 or higher
            • Processor: 1 gigahertz (GHz) or faster
            • RAM: 1 GB (32-bit) or 2 GB (64-bit)
            • Hard disk space: 1.5 GB
            • Libraries:
            o .Net Framework 4.7.1
            2. If #1 is OK:
            Uninstall ZAPTEST completely, delete its directories at the , then install it again and restart the machine.
            Please let us know if the above fixed the issue.
