How ZAPtest will connect to ODBC with DSN
Home Forums Ask Expert How ZAPtest will connect to ODBC with DSN
  • #32833
    Venkat M
      I am unable to find the snippet of how ZapTest will connect with databses via ODBC – DNS
      Please help on this.
      Regards
      Venkat
      #32843
        Hello Venkata,
        ZAPTEST does not provide built-in utility to query a database.
        Instead you can use the ADODB object.
        This is an example for SQL Server. Please search the WEB for additional information.
        ‘create DB objects
        Set objConnection = CreateObject(“ADODB.Connection”)
        Set objRecordset = CreateObject(“ADODB.Recordset”)
        ‘This connection uses local windows authenticated user
        objConnection.Open “DRIVER={SQL Server};Server=ZAPDEMOSQL54SQL2020;Database=OLDB;Trusted_Connection=yes;”
        ‘This connection uses SQL authentication
        ‘objConnection.Open “Provider=SQLOLEDB;Data Source=ZAPDEMOSQL54SQL2020;Database=OLDB;User ID=’‘;Password=’‘;”
        ‘run query
        ContextId = 123456
        Dbquery=”SELECT TOP 1 ID FROM [Transaction] NOLOCK WHERE ContextId ='”& ContextId &”‘ ORDER BY 1 DESC”
        objRecordset.Open Dbquery,objConnection
        TransactionID = objRecordset.fields(“ID”)
        objRecordset.Close
        objConnection.Close
        set objRecordset=nothing
        set objConnection=nothing
