How to use Zap-Fix with Linux?
Home Forums ZAPTEST Old Posts How to use Zap-Fix with Linux?
  • #30480
      Hello AlishaM,
      Basically you need to start with configuration of the Linux OS for automation with ZAP-fiX, to do this please follow these steps:
      1. You will need to install a VNC server;
      To do so, launch the terminal (Make sure your user has permissions to install packages)
      2. Type "apt-get install tightvncserver", wait until the installation is complete.
      3. When done, execute the command "vncserver". if executed for the first time, you will be required to define a password. write down the X desktop number (It indicates the last digit of the VNC server’s port number).
      4. Now you can execute QTP and Zap-fix for the required automation.
      Please contact Zap if you need more help.
