How to use Zap-Fix based scripts in Load-Runner?
Home Forums ZAPTEST Old Posts How to use Zap-Fix based scripts in Load-Runner?
  • #30540
      Basically you are using the ZPX (Zap-Fix) based testing scripts with LR (Load-Runner) the same way you use any other QTP based scripts:
      This is because ZPX is an Add-in to QTP, and ZPX based scripts are eventually QTP based scripts.
      P.S. Zap published the ‘ZAPGEN’ application which behaves just as the LR:
      It allows you to execute any QTP and ZPX based scripts as load test (Performance testing) on any platform (Including all mobile devices) and on any cross-platform Browsers and Devices.
      Please check our latest ‘ZAPGEN’ page at:
      http://www.zaptechnologies.com/products/zapgen
      For more help please contact Zap.
