how to use the scrollto and mousemove
Home Forums Ask Expert how to use the scrollto and mousemove
  • #31233
      Hello ckiran!
      Thank you for using ZAPTEST
      ScrollTo method have to be used prior to the validation of the objects that not visible e.g. objects that not on the main screen.
      In your example objects “ACCESS YOUR HEALTHCARE SECURIT”, “Please Select Your M”, “Image Object 36” and “Image Object 31” have to be visible on the main screen immediately after page load and next object (“Image Object 34”) seemed to be laid below the main screen.
      Also you don’t need to use MouseMove prior to Click method – in “click” mouse will automatically moves to an object. MouseMove really useful when you working with drop down lists activated by simple placing cursor onto it (but not need to be clicked).
      Other then that your syntax looks correct.
      ZAPTEST team
