How to use list via Zap-fix?
Home Forums ZAPTEST Old Posts How to use list via Zap-fix?
  • #30505
    Hogan Rotem
      We’re using Zap-fix for some time and wedo not understand how to use its Lists feature, please help.
        1. To start, we click on the "Add" button and select "List" as the object type.
        2. Select the list from the AUT (Application Under Test) until the very last visible row, using the appeared square. When done, give the list a name.
        3. Set the number of rows on the list:
        The number of rows meaning the number of visible rows in the list of the AUT.
        P.S. A list should be used only for single column, in a list with 2 columns:
        If you would like to use both columns, you can either create 2 different lists for each column, or create a table.
