How to use ALMQC with Zap-fix?
- This topic has 1 reply, 2 voices, and was last updated 10 years, 1 month ago by
In order to enable QC to run a Zap-fix based automated tests, please follow these steps:
1. In QTP go to the Options menu -> Under the Run section, check "Allow other HP products to run tests and components".
2. Go to the Test Lab module in Quality Center and run an automated test case which uses the ZAP-fiX add-in for QTP.
3. Select "Run All Tests Locally" option or specify a remote host name.
4. Click the "Run" button. If you are using a local host to execute the test, let it run until completion before using the mouse or keyboard again.
When finished, close the runner and check the results.
