How to upload Zap based tests to ALM?
- This topic has 1 reply, 2 voices, and was last updated 10 years, 7 months ago by
Hello AlishaM,
The Zap R&D Dept. working to implement all the ALM relationship features into teh Zap-fix Standalone version, we hope it will be published in the near future in the next builds.
For now you can do the following:
When installing Zap-fix Standalone version you also install the Zap-fix Addin for UFT;
If you have UFT installed as well you can use it with the combination of Zap-fix Addin feature to create a Zap based automated tests and use the build-in UFT mechnism to save the tests into ALM.
Note: Some of Zap-fix Addin for UFT methods cannot be recognized by the Zap-fix Standalone version.
