How to swipe up or down in ios?
Home Forums Ask Expert How to swipe up or down in ios?
  • #32739
      Good morning
      I would like to use a single script to select the phone prefix for both Desktop, Android and iOS device.
      How do I select a prefix in iOs that is above or below the “+39” (default)?
      I tried with scrollTo method (line 14) but I get ‘Incorrect syntax used for method “ScrollTo”‘ error (https://www.zaptest.com/user-zone/product-training/zaptest/methods/method-swipeto)
      Thanks for your help.
        Hello marco.malziotti ,
        Basically I’ve found 2 mistakes in your test:
        1. In line #3 you use the ScrollTo method to scroll to an object before the test launches the actual AUT (Application Under Test).
        2. In line #14 you are using the ScrollTo method while the actual syntax you’ve typed is more similar to the SwipeTo method:
        If you actually decided to use the SwipeTo method you need also to add the last 2 method’s attributes (Speed of swiping and the delay before swiping).
        Also the URL you’ve added in your post refers to the SwipeTo method and not to the ScrollTo method.
