How to specify similar objects in Zap-fix?
Home Forums ZAPTEST Old Posts How to specify similar objects in Zap-fix?
  • #30500
      Basically you can use several ZPX (Zap-fix) build-in properties to get each similar object with its own unique recognition – Here are some of the main ZPX properties you can use:
      – "Appearance" – With its sub-property "Order", you can specify each similar object by its ordinal unique index number.
      – "X", "Y", "Width" and "Height" – With these properties you can specify the exact unique location of each object (Note: It is best to specify the coordinates after opening the AUT (Application Under test) in its maximized size (Full screen)) – To get the exact coordinates of an object you can use the "XY Tool" in the upper-left ZPX toolbar.
      Hope this helped
