How to set connection to zapFarm?
Home Forums ZAPTEST Old Posts How to set connection to zapFarm?
  • #30482
      Please follow these notes to connect to zapFarm:
      [u:i82g3un9]Browser requirement:[/u:i82g3un9]
      To be able to use zapFARM you will need a browser that fully supports HTML5. To check if you browser support HTML5 you can check here:
      http://html5test.com/
      We recommend Chrome since it provides the best HTML5 support at this time.
      [u:i82g3un9]Ports used by zapFARM:[/u:i82g3un9]
      zapFARM uses ports 5900-5920. If you have any issues connecting please check with your network admin if these ports are open for outbound communication.
      [u:i82g3un9]Connecting to the device:[/u:i82g3un9]
      Navigate to the zapFARM url: http://access.zapfarm.com/#
      [u:i82g3un9]Connecting to the device using mobile viewer:[/u:i82g3un9]
      Contact your ZAP representative and request the port and password of the device we’ve set up for you.
      Then type the address of the device, which will look like this: access.zapfarm.com:59xx into the mobile viewer connection dialog and use the password provided.
