How to run number of Zap-fix tests one after the other?
Home Forums ZAPTEST Old Posts How to run number of Zap-fix tests one after the other?
  • This topic has 1 reply, 2 voices, and was last updated 10 years ago by Sasha ZAP.
  • #30651
    Rob Kites
      We have several Zap-fix Standalone version’s based tests and we need them to run one after the other number of times:
      How can we do it?
        Hello RobKites,
        Basically there are 3 ways you can run multiple ZAPTEST’s (The new name for the Zap-fix Standalone version) tests:
        1. Create a single Drive test and add to it as many calls as needed to your Zap tests using the runtest method (runtest "Directory+name of the test.zap"), you also can add a loop to run several tests over and over again as many iterations as necessary.
        2. Use the Multirun feature in ZAPTEST.
        3. Using utilities such as MS Windows’ based Task Scheduler utility to select which files to run and which apps to kill.
