how to read a range of text in a UI and export it
Home Forums Ask Expert how to read a range of text in a UI and export it
  • #32227
    Ariel Cairo
      just starting on Zap test, i have a small assignment wherein i will have to view a certain webpage which contains txt, how can i make zaptest read not just 1 line, but 5 to 10 lines or more, and how i can it be exported to excel.
        Hello ryhelcairo,
        In order to get more the 1 line of text from a single object and save it to an Excel file you can do as follow:
        1. Scan the GUI using “Scan Multiline” (Right to the Scan GUI button there is a small arrow, when you click on it you will see different scanning GUI types).
        2. This is an example code how to getting an object’s multiline text and saving it to an Excel file:
        ZAP.Datatable.ImportExcel(“C:Test.xls”)
        strData = Application(“Application”).View(“View”).Object(“Multiline Text Object”).GetText
        ZAP.Datatable.SetValue “Name of Spreadsheet Columns”, strData
        ZAP.Datatable.ExportExcel(“C:Test.xls”)
        P.S. In order to get started with ZAPTEST please visit the “ZAPTEST Beginner Tutorial” page at:
