how to Launch the tool
Home Forums Ask Expert how to Launch the tool
  • This topic has 1 reply, 2 voices, and was last updated 7 years ago by Kirill Bulatnikov.
  • #31939
    Sowmiya S
      I am unable to lauch the software(exe) using zaptest for windows application.
      kindly help me start the scripting for below functionalities
      1. launch the exe
      2. exist check of exe
      3. bringing the control to the particular tool if more than one tool opened
      4. closing the exe or tool
      #31940
        Hello, thanks for using ZAPTEST
        You need to scan your application first to create application in repository.
        Next use “launch” method over ti your application. For example notepad:
        Application(“Application”).Launch “C:WindowsSystem32notepad.exe”
        Use “exist” method in next step
        Application(“Application”).Exist
        Then performs operations with application based on the methods available in ZAPTEST
        And finally close it:
        Application(“Application”).Close
        That’s it.
