How to launch exe file using zaptest?
Home Forums Ask Expert How to launch exe file using zaptest?
  • #31804
      Hello gsingh2014,
      In order to launch an exe file (And basically any other type of file, including web page) you use the “Launch” method – For example to launch the OS Calculator app you can write:
      Application(“Calc”).Launch “C:Windowssystem32calc.exe”
      Please check other attributes of the method by checking its appeared tooltips.
      Also you can check our Beginner’s Tutorial at:
