How to get test results after it runs in ALM?
Home Forums ZAPTEST Best Practices How to get test results after it runs in ALM?
  • This topic has 1 reply, 2 voices, and was last updated 9 years ago by Alisha Michaels.
  • #30855
      The tests’ results of ZAPTEST which ran via ALM will be stored as attached HTML file in the “Test Runs” module, in the specific test’s execution record:
      If you do not see your test’s record it means:
      1. There is a filter which was set to the specific page’s view and prevents viewing the required test.
      2. There is limitation on the page to display only a specific number of results (It appears above the viewed results’ table at the its top-right corner), remove this limitation and you’ll get the entire list of records.
      The results can be viewed by any Browser, same as opening the results for a test which runs locally.
      #30856
      Alisha Michaels
        Thank you Sasha for your help.
