How to get Help in Zapfree?
Home Forums Ask Expert How To How to get Help in Zapfree?
  • #30683
      Basically there are several ways to get help regarding Zapfree:
      Help on its methods:
      Today we’re working to implement videos on all valid methods for Zapfree, these videos we plan will be installed rather on the tool itself(Under the Help section) ;
      Another way is to check the Readme file (also under the Help section), which contains all the information for ZAPTEST but some of this information is relevant to Zapfree as well (Zapfree is basically named ZAPTEST Community Edition and it is basically derivative of ZAPTEST);
      Also you can get access to Zap’s portal User Zone section (Contact Zap to request access to the User Zone), in the User Zone you’ll find a lot of information about Zap and all its products, including their methods.
      Help on how to get started:
      Basically the attached Tutorial video can guide you through the main features of Zapfree and help you to get started with Zapfree.
      Technical questions:
      Some of the technical questions you’ll find in Zap portal, but for others you’ll need to contact Zap (You can do it through Zap’s Forum (http://www.zaptest.com/forum/index ).
      Please contact Zap for further questions
      #30684
      Hogan Rotem
        Thank-you Sasha.
        #30685
          Some of the technical questions you’ll find in Zap portal, but for others you’ll need to contact Zap (You can do it through Zap’s Forum (www.zaptest.com/forum/index ).
          #30686
            #30687
            Hogan Rotem
              Thank-you Sasha.
