How to get full text paragraph
Home Forums ZAPTEST Old Posts How to get full text paragraph
  • #30771
    Curtis Don
      We need to compare several paragraphs from different text sources. how can we do that with ZAPTEST?
      Please help us on this.
        Basically there are 2 main options to help you on this:
        1. The workaround solution:
        If you specify each text as a table where each paragraph is basically 1 cell of the table, you can then “run” through the table cells of each text (Using looping) and compare 2 or more such text-tables’ cells.
        2. The build-in solution:
        In the upcoming new ZAPTEST version (v15.0.77, which was not published yet and in its testing phase now) already contains the Block and the Multiline objects’ types which will allow to capture more then 1 line of text in a single object.
        #30773
        Curtis Don
          Thank-you Sasha for the quick response.
