How to execute an application using Zap-fix?
Home Forums ZAPTEST Old Posts How to execute an application using Zap-fix?
  • This topic has 1 reply, 2 voices, and was last updated 10 years ago by Sasha ZAP.
  • #30649
    Curtis Don
      Is there a methodcommand in Zap-fix standalone version (Not the UFT add-in) to execute a specific utilityprogram:
      We think also to try to execute it via CMD.
        Basically you can use the following code to execute the app:
        SystemUtil.Run "Directory of the app"
        Or if you want to run first the CMD you can write the following code to execute CMD:
        SystemUtil.Run "C:Windowssystem32cmd.exe"
        Then you scan the CMD window using ZAPTEST (The new name for the Zap-fix Standalone version) and using its objects you write:
        Application("Name of the capture Application object").View("Name of the captured View name").Type "Directory of the app" & "{ENTER}"
