How to emulate the scrollbar in Zap-fix?
Home Forums ZAPTEST Old Posts How to emulate the scrollbar in Zap-fix?
  • This topic has 1 reply, 2 voices, and was last updated 10 years ago by Sasha ZAP.
  • #30657
      We have a scrollbar in our web based application (Which we are testing):
      How do I identify this object in Zap-fix (In UFT sometimes there was a way to record an action on a scrolbar?
        In UFT only in some applications’ types it manages to recognize the Scrollbar as an object, in most of situations there is a need to use descriptive programming – Only Zap-fix gives you a recognition of scrollbar in all types of applications:
        1. If there is a need to emulate a scroll from one place to a different in a page you can set the object as Swiper (In the Workbench).
        2. You can set a specific object in the Workbench which will recognize the Scrollbar in a test.
        3. You can do a simple recording which will capture the scrollbar in the best way.
