How to create a test suite in Zaptest
Home Forums Ask Expert How to create a test suite in Zaptest
  • #32699
    Nidhi Kashyap
      Hi All
      I am new to Zaptest. I have successfully created test scripts in ZAPTEST. I want to create a tets suite now and also want to prioritize my test cases. Please suggest me how to create a test suite in ZAPTEST.
      Thanks in advance.
      Regards,
      Nidhi
      #32700
        Hello Nidhi,
        Basically in order to create tests’ suite you need to create a driver test which will contain calls from all your external test cases, this feature is only available in the ZAPTEST Enterprise Edition – Please check the differences between ZAPTEST Free and Enterprise Editions at:
        https://www.zaptest.com/get-started?free-trial
        In the ZAPTEST Free Edition you can only create a single test, this test can contain all your test cases’ steps, but please note that in the Free Edition you’ll be able to use only 3 rows of Datatable.
