How to create a “for” Loop?
Home Forums Ask Expert How to create a “for” Loop?
Viewing 6 posts - 1 through 6 (of 6 total)
  • #31874
      Hello Andreas. Thanks for using ZAPTEST.
      No loops allowed in Free Edition – you need to upgrade to Enterprise. Please see comparison table below
      https://www.zaptest.com/zaptest-free-edition
      Andreas Gosch
        Thanks for the fast answer, i have another question, is there a shortcut to interrupt a test while it is running in the browser, because without a loop i have to use an infinite loop to make this work for me.
        Best Regards
        #31876
          Andreas, there are “StopTest” and “StopIteration” methods. Also you can set a breakpoint for some of the steps and then return to execution by clicking “Run” once again.
          Andreas Gosch
            Hi, i have seen these two methods but sadly in the free version you cannot say how often a sequence should be executed. A breakpoint doesn’t help there because then i have to execute every click again for the test.
            Best Regards
            #31878
              You can try to implement if-else trigger for that.
              BTW If there is a chance you have the budget for the enterprise license purchase we can schedule product demo and discuss your test objectives.
              Andreas Gosch
                Hi, the tip with if-else sounds good, is it possible in the free version to seperate sequences from each other, What i mean is something like this: Click on this button until a specific message is visible and then click this button again until another message arrives. This should be possible with boxed if-statement but would be nicer with seperated sequences.
                Best Regards
