How to click “Done” button?
Home Forums Ask Expert How to click “Done” button?
  • #32713
      Good morning
      After entering the password I would like to click on Login.
      One line is not enough, I have to write two (see lines 3 and 4 in .zap attachement):
      1- to make the keyboard disappear
      2- to select “Login” button
      Is there any way to simulate pressing the “Done” key in the given attached screen (see .png attachement) to remove the keyboard and then click on “Login”?
      Thank you.
      Details: ZapTest version 20.2.4, Android 7.0
        Hello marco.malziotti,
        Basically if any new object (Even temporary) appear in the UI you must add it to the Object Repository:
        In some cases it is recommended to create a new  View and even a new Application to such object, even if it appears only once and even if it appears in an existing already scanned Application.
        Please check the attached updated test with the new object I’ve added to it (“LeasysGo-login_Updated.zap”):
        I’ve used your attached screenshot to add the Done object, it is best to update this screenshot from a real app.
        Hope this helps.
        P.S. For more understanding how ZAPTEST works please refer to our ZAPTEST Beginner Tutorial at:
        Also you can check our extended Documentation library at:
        ZAPTEST Expert
