How to click a changed day in a calendar
Home Forums ZAPTEST Old Posts How to click a changed day in a calendar
  • #30790
    Hogan Rotem
      We want to create a test where there is a click on a different day in a calendar, please advise how to do it.
        Basically there are a few ways to click on a dynamic object (In your case it is a day in a calendar that changes each time):
        1. You can add one of the calendar’s days as an object in the Workbench, and by using the “SetProperty” method to update its X and Y coordinates (In its Properties) you can control each execution of the object in its new required day’s position in the GUI.
        2. Do as #1 but this time to change the “Text” property of the object which will specify the required day to be clicked.
        3. Another option is to use the “MouseMove” method to move the mouse to its required day clicking, and run the “KeyPress” method wherever the mouse is located.
        4. In the latest ZAPTEST versions which will be published soon, you can see the whole calendar as a table and use the “ClickCell” new updated method to click on a specific table’s cell, which is basically a specific day on the calendar.
        #30792
        Hogan Rotem
          Thank-you Sasha for the detailed and quick response.
