How To Add Devices to the Zap-fix Menu
Home Forums ZAPTEST Old Posts How To Add Devices to the Zap-fix Menu
  • #30618
      Hello AlishaM,
      1. Make sure you have created the ZPD device connection files.
      2. In ZAPTEST (The new name for Zap-fix) open the "Devices" menu and click "Configure..".
      Browse to the folder containing the ZPD files and click ‘OK’.
      3. When you open the "Devices" menu, all the devices you have configured will be visible.
      4. To connect to a certain device, simply click its name in the "Devices" menu:
      ZAPTEST will open the Mobile Viewer and automatically connect to the selected device.
