File read operation
File read operation
Home Forums Ask Expert File read operation
  • #32177
      Hello bhavin.acharya,
      Please refer to the online ZAPTEST Beginner Tutorial to get familier with ZAPTEST:
      In general you need to do the following:
      1. Execute the TextWord file you need to do the test upon.
      2. Using ZAPTEST scan its GUI.
      3. Remove unnecessary objects (Not a must).
      4. To execute a file use the method “Launch”.
      5. Use the method “GetText” to capture a text, use a condition to check if the captured text is the expected one, and use a loop to go over the entire text to find the expected string (Or use VBScript method such as “InStr”).
      6. Use method such as “CusomReport” to report the final result in the test’s final report.
      To get more understanding of the methods you can check the following “How-To” documentation:
