Field Clear and how we check values
Home Forums Ask Expert Field Clear and how we check values
  • #31369
      Hello aqu,
      1. To clear out text-box you can just type nothing in it, for example:
      Application(“Application”).View(“View 4”).Object(“Image Object 6”).Type “”
      2. To check a value of an object you can use the “GetText” nethod, for example:
      strText = Application(“App”).View(“View”).Object(“Object”)GetText()
      If the above does not gets the text use the “True” method’s attribute, for example:
      strText = Application(“Demo”).View(“DemoView”).Object(“DemoTextObject”)GetText(true)
      For more help check out our tutorial at:
