Devices are not found
Home Forums Ask Expert Devices are not found
Viewing 13 posts - 1 through 13 (of 13 total)
  • #31966
    Mizanur Rahman
      After clicking Device manager a small window appear and it show no devices are found. I already install Android USB Driver for Windows. Now how can i configure the next step. Please give proper suggestion.
      Thanks in Advance.
      #31967
        Hello mizanur. Thanks for using ZAPTEST.
        Please refer following video:
        Configuring Mobile Devices
        Please let us know if you still need the assistance after that.
        Mizanur Rahman
          I watch the video but in my computer “device manager” does not have the android ADB interface. so what should i do next?
          #31969
            OK what phone you are trying to connect? What version of the USB Android driver do you have?
            Can you see the phone connected besides ADB interface?
            #31974
            Mizanur Rahman
              Sorry for the late reply. I do not have any android driver in my device manager. How can i configure that.
              #31975
                Hello mizanur
                ADB is the thing I am talking about. In fact looks like you installed it yet it may be incorrect version etc.
                BTW did you also enabled the Developer Options in your phone settings? It is required for the accessability of the phone by ZAPTEST application.
                Mizanur Rahman
                  Yes Developer option is enabled and I use for application debug. My device name is Xiaomi Redmi Note 3.
                  #31977
                    OK I see
                    You should download ADB driver next. Please google “xiaomi redmi note 3 adb driver”
                    As per what I found you should download following version:
                    adb-setup-1.4.3.exe
                    Than install it and try to connect your phone.
                    Mizanur Rahman
                      Thank you. It is working. 🙂 🙂 🙂
                      #31979
                      Mizanur Rahman
                        I can connect now with my “xiaomi redmi note 3” device but when I try to connect with my other android phone which model is “BLU DASH X PLUS” , But this time it does not work.
                        Thanks in advance for the quick response.
                        #31980
                          Hello mizanur.
                          I guess you need specific ADB driver for this device (for example Samsung phones needs another driver too). So please check what version of the ADB suited for your 2nd phone and install it in addition to Xiaomi driver. And don’t forget to enable developer options on the phone as well.
                          Mizanur Rahman
                            I tried google to search for my “BLU DASH X PLUS” ADB drivers but it also suggest the “adb-setup-1.4.3.exe” to install. Can you help me for searching the correct version of the ADB suited for my Device. And one more thing that developer options on my phone is enabled.
                            #31983
