clicking a specific link
Home Forums Ask Expert clicking a specific link
  • #32248
      Hello sridhar5.ms. Thanks for using ZAPTEST.
      If your “service id” appears on the screen at the same place then you can create the manual object covering the space when the text appears and applying GetText method to it. Please note that you also MUST select relative parent object for it (as an anchor) as well to make sure you are looking for the text in the same particular place. The relative object should be constant and should be either OCR (preferred) or Image.
      The result of GetText can be stored as variable, can be written to datatable or output to the text results (combining all 3 ways – it’s up to you).
      Kirill.
