When checking the final test’s results and expending the Exist executed line of test, does it show that it captured the correct count details as they appear in screen (i.e. ‘40’ or ‘50’)?
If not then it appears the count details’ object is not being recognized properly by ZAPTEST, meaning it is not SET to capture the proper data – In order to set an object to capture required data, especially dynamic data that its value orand location may change for example, you need to update some of the object’s properties orand use features such as Relative Object and or even Area Object;
Please check our online Beginner’s Tutorial at:
P.S. If you still will have difficulties to capture object’s correct value please attach your testing script (The *.zap file) and 2 screenshots:
One for the 50 rows’ results and the other for the 40 rows’ results.
I’m trying to use the tool to test macro execution in MS Project with Windows 10. It seems to work fine with button clicks but I was getting confusing results with GetText and ReportText. I kept thinking it was my OCR settings, my window location settings but I was getting random data often. I finally added HighLight before doing ReportText. Sometimes it highlights the correct spot but often it is another object, sort of another object or just a random location. When it highlights the correct location then I get the correct answer.
Looking for a recommendation to solve the problem. I’ve included screen shots.
It is possible your Results’ object is not recognized properly during runtime:
Please check our online Beginner’s Tutorial at: http://www.zaptest.com/tutorial
Thank you. I had assumed that relative object was only needed if the screen was moving and that the object property coordinates gave its positioning. The tutorial made the relative positioning as a suggestion but it seems like it is a requirement.
After making the images relative to a button everything worked! Thanks for the help.
You must activate your account before using it, please open the email that was sent to the email address that you used to set-up your account and confirm your email address.
We use cookies on our website to give you the most relevant experience by remembering your preferences and repeat visits. By clicking “Accept”, you consent to the use of ALL the cookies.
This website uses cookies to improve your experience while you navigate through the website. Out of these, the cookies that are categorized as necessary are stored on your browser as they are essential for the working of basic functionalities of the website. We also use third-party cookies that help us analyze and understand how you use this website. These cookies will be stored in your browser only with your consent. You also have the option to opt-out of these cookies. But opting out of some of these cookies may affect your browsing experience.
Necessary cookies are absolutely essential for the website to function properly. These cookies ensure basic functionalities and security features of the website, anonymously.
Cookie
Duration
Description
cookielawinfo-checkbox-analytics
11 months
This cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Analytics".
cookielawinfo-checkbox-functional
11 months
The cookie is set by GDPR cookie consent to record the user consent for the cookies in the category "Functional".
cookielawinfo-checkbox-necessary
11 months
This cookie is set by GDPR Cookie Consent plugin. The cookies is used to store the user consent for the cookies in the category "Necessary".
cookielawinfo-checkbox-others
11 months
This cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Other.
cookielawinfo-checkbox-performance
11 months
This cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Performance".
viewed_cookie_policy
11 months
The cookie is set by the GDPR Cookie Consent plugin and is used to store whether or not user has consented to the use of cookies. It does not store any personal data.
Functional cookies help to perform certain functionalities like sharing the content of the website on social media platforms, collect feedbacks, and other third-party features.
Performance cookies are used to understand and analyze the key performance indexes of the website which helps in delivering a better user experience for the visitors.
Analytical cookies are used to understand how visitors interact with the website. These cookies help provide information on metrics the number of visitors, bounce rate, traffic source, etc.
Advertisement cookies are used to provide visitors with relevant ads and marketing campaigns. These cookies track visitors across websites and collect information to provide customized ads.
