Can’t run same script in different systems
Home Forums Ask Expert Can’t run same script in different systems
  • #32379
      Hello vindavarapu. Thanks for using ZAPTEST.
      Please let us know what version of the ZAPTEST do you use?
      Kirill,
      vaidehi inda
        Hi Kirill,
        Currently I’ve upgraded to 19.5.5 version and failing on other 2 systems when run (Passed with 100% on developed system, 1080P 150% in current version also). But I didn’t run the script on other systems in previous versions though. My script is couple of versions previous to current version. May be like 3 to 4 versions previous to current version.
        Vaidehi
        #32392
        vaidehi inda
          Hi Kirill,
          Can you please help me to solve my question.
          Vaidehi
          #32393
            Hello vindavarapu
            In fact we fixed the issue like that quite long ago. Personally I am using 2 displays (laptop one and big external one) with different resolution and scale and it works perfectly.
            What application you working with? Is it the browser or some standalone application? Is this issue applicable to all of your tests?
            Are you able to upload the script to the thread – I will try to check out what may be wrong?
            Kirill,
