Can we use Zap-fix with Unix based applications?
Home Forums ZAPTEST Old Posts Can we use Zap-fix with Unix based applications?
  • #30624
      Yes definitely, ZAPTEST (This is the new name for the Zap-fix standalone version) is capable creating all the required automated tests in all types of applicationsplatformsOSetc.
      Using the ZAPTEST you can also upload the tests to QCALM, and by using the Zap-fix Add-in for QTPUFT you can create functional tests which can be handled with HP applications such as Load-Runner.
      Also we have the ZAP-fiX Unix Viewer which offers a full functionality of HP ALM for Unix based applications, and by connecting it to the Unix based machine you can use it remotely to do the same testing as you are doing it locally.
