Can we use Proxy?
Can we use Proxy?
Home Forums Ask Expert How To Can we use Proxy?
  • #30762
    Jack Smith
      We want to start using our Proxy Server to access the Internet from within our facilities:
      We’ve downloaded the free edition of Zaptest (ZAPTEST Community Edition), how can we set in it our Proxy credentials?
        Basically the Proxy support was set in the latest Zapfree (AKA ZAPTEST Community Edition) version (Which will be published in the near future):
        This means that you can access the ZAPTEST License Server (Which can be installed in a remote machine) and access your web based applications (which reside in the Internet) via Proxy.
        These are the instructions to allow a certain machine to use your Proxy Server:
        1. Open Internet Explorer Options. Go to Connections tab and click LAN Settings.
        2. Enable “Use a Proxy server” and type your proxy server’s IP/port and save the settings.
        3. Test that internet and proxy works – simply in the browser type a website and see if it works.
        4. Open Zapfree – it should be able to Login to the ZAPTEST License Server (If you installed it in a remote machine) and then launch, if it launches without errors, the Proxy works!
        #30764
        Jack Smith
          Thanks Sasha for the quick response.
