Can we use only ZAPTEST for automation?
Home Forums ZAPTEST Old Posts Can we use only ZAPTEST for automation?
  • This topic has 1 reply, 2 voices, and was last updated 10 years ago by Sasha ZAP.
  • #30647
    Curtis Don
      Although we have some apps which we need ZAPTEST to automate for us (Which UFT cannot do it), we still find ourselves working with UFT a lot:
      Is there a way to work only with ZAPTEST instead?
        Basically you do able to work only with ZAPTEST:
        First ZAPTEST can automate all the apps types and platforms, and work on all environments that UFT can;
        Also ZAPTEST can do much more then UFT, basically it can automate a business process in ANY environmentOSApp typeplatform there is and can be adjust and adapt to be able to automate new environmentOSApp typeplatform as well.
        Zap R&D works now to create a very sophisticated converter which will convert UFT’s automated tests into compatible tests which can run on the ZAPTEST as well:
        This will enable you to move all your UFTQTP based tests to work on the ZAPTEST and continue working only with ZAPTEST.
