Can we use Excel file in zap-fix?
- This topic has 1 reply, 2 voices, and was last updated 10 years, 7 months ago by
Basically in our latest Zap-fix Standalone versions there is already the following Excel file’s feature:
Datatable.ImportCSV(<path>) – Imports Datatable to CSV during runtime.
To read from a runtime Excel datatable:
x = Datatable.Value("Name of the Spreadsheet")
To write into a runtime Excel datatable:
Datatable.Value("Name of the Spreadsheet") = x
Our R&D Department works to implement the Export method as well.
Until the new method will be published in teh next build you can use the following VBScript code to importexportreadwrite into and Excel file:
Set objExcel = CreateObject("Excel.Application")
objExcel.Visible = True
Set objWorkbook = objExcel.Workbooks.Open("C:Test.xls")
Set objWorksheet = objWorkbook.Worksheets(1)
‘Write into Excel Worksheet
objWorksheet.Cells(1, 1).Value = "Number"
objWorkbook.Save()
‘Read from Excel Worksheet
value = objWorksheet.Cells(1,1).Value
objExcel.Quit
Set objWorksheet = Nothing
Set objWorkbook = Nothing
Set objExcel = Nothing
