Can we create like a standard automation template
Home Forums Ask Expert Can we create like a standard automation template
  • #31285
    Alex ZAP
      baguiojojo – Thanks for your post!
      When organizing Test Automation (TA) with combination of non-scripter Subject Matter Experts (SME) and experienced TA Specialists you can use approach of allowing SMEs to use ZAPTEST Visual Scenarios (VS) developed with Recorder.
      This approach will be more cost efficient form TA development and maintenance.
      SMEs can develop VS, where team of TA Specialists using 1SCRIPT will fast and efficient convert them to executable TA scripts; and will create supplementing test documentation using DOC.
      Keeping TA development and maintenance within the TA Specialist team will prevent any re-work of the TA scripts that might be caused by SME, and will allow TA Specialists to reuse commonly developed TA components and modules (Object Repositories, functions etc…).
      Please advise if this approach will work for your team?
      Thanks for using ZAPTEST!
      Alex ZAP
