BrowserStack with Zaptest
Home Forums Ask Expert BrowserStack with Zaptest
  • #32785
    Michel Belanger
      I saw this https://www.zaptest.com/zaptest-videos/zaptest-with-browserstack
      But that doesn’t show how to achieve it!
      I would need help running m-run tests on BrowserStack, please 🙂
      #32786
        Hello michel.b.belanger,
        Basically there are 2 ways to run testing scripts on multiple Browsers orand multiple devicesmachinesOS:
        1. Setting different data in the “Launch” method’s parameters – Please check the following Documentation page explaining how to set and use the Launch method:
        https://www.zaptest.com/user-zone/product-training/zaptest/methods/method-launch
        2. Using the M-RUN ZAPTEST feature which allows you to connect several machines to run the same single testing script – Please check this Tutorial video on how to use M-RUN:
        M-RUN
        If you are using ZAPTEST Free Edition please check the following page to know its features’ limitations:
        https://www.zaptest.com/get-started?free-trial
        P.S. For more understanding on how to use ZAPTEST please check our “ZAPTEST Beginner Tutorial” page at:
        And to find all required documentation regarding ZAPTEST please check the “How-To” page at:
