Auto-Generate Test Documentation in HP ALM
- This topic has 0 replies, 1 voice, and was last updated 8 years, 9 months ago by
Home › Forums › ZAPTEST › Best Practices › Auto-Generate Test Documentation in HP ALM
If you wish to publish test’s steps in ALM -> Test Plan, the NEW FEATURE release, ZAPTEST’s DOC generator, enables you to do it:
Connect to ALM and create the automated test in ZAPTEST, then go to the new DOC tab and click the “Generate from script” button to generate the tests steps, it is simple as that:
Now you can save the generated steps in ALM -> Test Plan -> Your test, and also save them as a Word orand an HTML file.
