Android App GUI does not load. (app is using AWS)
Home Forums Ask Expert Android App GUI does not load. (app is using AWS)
  • #30974
      Hello amahapatra,
      Thank you for reporting this issue.
      We are looking into it, and will follow up soon.
      #30986
      Arnab Mahapatra
        thanks for resolution
        the problem was within the app itself (AWS is not the issue). The “Flag_Secure” was turned on in the code base which prevents screenshots and displaying of GUI of app in other tools.
        Our Dev team will remove the “Flag_Secure” from the source and recompile the app
