After Zap-fix installtion different issues appear
Home Forums ZAPTEST Old Posts After Zap-fix installtion different issues appear
  • #30452
      Hello Rob,
      Thank-you for your questions.
      We’re sorry you’re experiencing the mentioned issues.
      1. Regarding the missing ZPX (Short for Zap-fix) from the Start menu:
      Please reboot the machine and you’ll see the Zap-fix again in the Start menu.
      2. Regarding the error the ZPX License Server showed when trying to start it:
      Please uninstall ZPX completely, reboot the machine, install it again, reboot the machine again – This should fix the issue and you’ll be able to StartStop the ZPX License Server as needed.
      3. Regarding the message ZPX shows when tryign to scan a UI issue:
      Make sure ZPX was installed on the machine after QTPUFT was installed on it:
      If you first installed ZPX prior QTPUFT you need to uninstall them both, install first QTPUFT, reboot the machine and check if they work successfully, only then install ZPX, rebot the machine and test it – This should fix this issue.
      P.S. There are more options to fix these issues, but the mentioned fix is the quickest and the most reliable ones.
